Saltar al contenido principal
My MBP does not go off, BUT RESTART
MacBook Pro 17" Models A1212
Immediately restarts every time I try to shut it down or put on stand-by, if I close the screen continues to reboot without stopping. The only way to shut it down is to hold down the power button.
If I try to shut down the terminal, the result does not change, it will restart immediately.
Groped to solve the problem, I tried everything I knew, the brief summary:
- I have repaired the hard drive with the appropriate utilities, and the program has reported that it had repaired some areas. - I have repaired permissions
- I formatted (Snow Leopard) by initializing the disk.
- I did all the upgrades I noted that the system automatically
- I reset the PRAM (x 3 times) and the SMC.
- I replaced the RAM
I did the hardware test and it gave me this result:
4M0T/1/40000002: Left side
At this point I do not know what to do, I can take it apart, but I have not the faintest idea what kind of hardware could cause such a thing.
Note that for the rest of the machine works perfectly.
Thank you in advance for your attention.
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Solución Elegida
I suspect that one of your fans has failed. Download and run smc fan control and see what it tells you: http://download.cnet.com/smcFanControl/3...
Fue útil esta respuesta?
Puntuación 3
1 comentario:
ok, I'll try as soon as possible, but that relationship may exist between warming and the fact that it will not shut? I have confirmed that the error code from the hardware test, refers to the fan left who does not work, but how this may affect the shutdown?
- de
Añadir tu respuesta
davidegatt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 1,197
