KitchenAid Dishwasher runs intermittently but doesn’t clean
Fills with water-wash cycle stops/starts for hours but not cleaning. Cancel-Drain works fine. I’ve replaced the sump and motor and the control board but still getting a 4-3 error, which is not showing up in any searches.
A lot comments mentioned the door actuator not making good contact with the door latch switch in this thread that describes the problem .
Whirlpool Dishwasher stops after filling with water
Model #KDTE104ESS4
Another clue-burnt wires leading to control board (disconnected during control board installation)
Update (11/08/2018)
Thanks for responding. Yes filter is clean.
I don’t think the sprayer arms are moving any water. The tub fills and sometimes sounds like it’s working but top rack not wet.
Es esta una buena pregunta?
8 comentarios
Did you check the float in the bottom right corner? If it’s stuck it won’t let the tub fill up properly.
- de Matt
Yes float is functional.
- de Curtis
When I replaced the control board I noticed the outside of the panel wires that go the control board look burnt. Should/can I replace those?
- de Curtis
is the error definitely 4-3?
- de Matt
Yes it’s 4-3.
- de Curtis
Mostrar 3 comentarios más
