Saltar al contenido principal
Repair guides and support for the Motorola Moto G6 Play, Released May 2018. Model number XT1922.
Preguntas 20 Ver todo
Moto G6 Play replacement screen 1mm too short
I know this is going to sound weird but I ordered a screen from 2 different suppliers for a Moto G6 Play and both replacement screens are 1mm too short. Everything lines up at the top and the shape is perfect but there is a gap at the bottom. The flex cables work and are a perfect match to the original. Anybody else have this issue?
Es esta una buena pregunta?
Puntuación 6
3 comentarios
Yes got the same problem, I recommend buying with frame assembly
- de
Our shops have ran into this issue as well. We now buy it with the frame only.
- de
Unable to find XT1922-9 replacement lcd w/ frame...
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Hey Jestin, I have since discovered there are 7 variations of the G6 Play. Some of them use a 150mm screen and some use a 152mm screen.
If the supplier doesn't specify, you will most likely get a 150mm.
I found an eBay seller that lets you pick which one you want and it worked great.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
I had the same issue today with the screen i received from a local supplier today. Everything works on it, its just short.
I end up replacing the screen anyway.
- de
iFixit sells genuine Motrola parts. I would sugget you search on iFixit for availability of the specific moto part you need in order to ensure a proper fit. The genuine parts are going to be a lot more reliable!
Puntuación 0
Añadir tu respuesta
brentongraber estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 2,225
