Ignition will not turn!
I have a 2004 Dodge Neon my ignition will not turn at all I've tried WD-40 smacking the key with a hammer adjusting the angle on the steering column but nothing is working I don't know if it is because there is a lock button behind the ignition that is causing the problem if anybody has any suggestions please let me know thank you very much. I am to the point where I will try anything. Except call a mechanic!
Es esta una buena pregunta?
2 comentarios
you tried turning the steering wheel from side to side to release the steering lock?
- de pollytintop
Thank you for the advice but I tried it many times I think my problem is with the ignition lock button that is located behind the ignition
- de Erin
