Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1103 / Procesador G4 de 1.25, 1.33, 1.42 o 1.5 GHz
I cannot eject my Instillation Disk
I was changing Admin Password with the instillation disk inserted, as I was instructed to, but a pop up sheet read “Disk needs to be Cleaned”. Now I can not eject the disk, the “Eject  Leopard Instillation Disk” is showing  in Bold with the Clover Leaf +Q but it is not responding when I press the keys.
My Keyboard is Qwerty so I tried to use the Windows Key on my keyboard  instead of Clover Leaf Command,, unfortunately no response,
Es esta una buena pregunta?
Puntuación 0
1 comentario
Your best bet is to borrow your friend’s keyboard made by Apple and use it to eject your disc. Otherwise you will have to disassemble your Mac mini and manually eject it.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
See if there is a paperclip diameter size hole to the lower right or left of the optical drive slot. If so this is an eject hole, use paper clip in the hole to eject.
That failing, shut it down and restart holding down the mouse.
Fue útil esta respuesta?
Puntuación 2
Does you find power led blinking or not. It shows that your dvd tray stuck. slightly press try in opposite direction and then press eject. Try this few time Or if you find any needle size hole,enter needle inside it to take disk out.
Puntuación 0
Añadir tu respuesta
Savlen Dempsley estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 540
