Saltar al contenido principal
Lanzado en julio de 2018, el MacBook Pro de 15", modelo A1990, presenta una pantalla de retroiluminación LED de 15.4 pulgadas con tecnología True Tone, TouchID y hasta 6 procesadores Core i9.
Preguntas 173 Ver todo
How to reset SMC on the 2018 MBP?
Instructions given on apple website at the link for T2 equipped devices are simply not working
https://support.apple.com/en-us/HT201295
The device simply boots up on attempting any of the 2 given combinations.
Please help
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
Can you explain what you are trying to reset. The more detail the better.
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
Here’s a guide on how to reset the SMC and the PRAM on your MBP. Hopefully it will work for you. If not, maybe @danj can assist you better if you provide more detail.
Cómo restablecer el SMC, PRAM y NVRAM en una MacBook Pro Touch Bar 2018
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Thank you Aaron. Yes, I attempted that, but the systems always boots up during the procedure, actually within 2-3 seconds of attempting any of the 2 alternatives
- de
Okay, hopefully Dan will be able to help you further. Sorry about that!
- de
Press Shift + control + option button with power at the same time and release after 60 seconds altogether and continuously watch the light on the magsafe it will change color of led for a short duration of time indicates SMC reset has been successfully done
Puntuación 0
11 comentarios:
Hello, and thank you for the kind reply.
This may work on older models, not the new 2018 with the T2 chip.
Also, And these models do not have a MagSafe.
- de
Is your battery detachable or not or with touch ID
- de
Systems with a T2 chip are very different than the older systems. Some settings are just not resettable. Depending on what the issue is we may need to use a different way.
- de
Yes, I realise that systems with T2 are different, and therefore requiring a different procedure for the reset. I followed the instructions on apple page for systems with T2, that Aaron also posted. but this is not working. the system simply boots up 2-3 seconds when attempting any of the 2 alternatives. That does not sound right
- de
SMS - What are you trying to re-set?
- de
Mostrar 6 comentarios más
Shift+control+option with power button
Puntuación 0
Aaron, I did this but it won’t restart. It was having issues charging. It just had a blinking red dead battery in the middle of the screen even though it was plugged in. I reset the SMC... and it never turned on and now doesn’t respond at all, I don’t even have the blinking battery anymore.
Puntuación 0
1 comentario:
@bpress - You really need to create a fresh question here with all of your systems details.
- de
Añadir tu respuesta
SMS estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 2,034
