Saltar al contenido principal
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
Preguntas 119 Ver todo
Samsung Galaxy Note 10.1 2014 Tablet won't turn on.
I have a four year old Samsung Galaxy Note 10.1 2014 tablet that won’t turn on anymore. I have tried charging it with many different usb cords in different power supplies and holding down every combination of of the power, home, and volume buttons, but the tablet never responds. Any help would be greatly appreciated.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
Has the tablet been dropped or gotten wet at all?
If not, if you know how to use and have a DMM (digital multimeter) you can use it to try start testing what may or may not be happening.
Usually when devices do not respond at all to the charger being connected, after you have tried different chargers and cables (which you’ve done) the next thing that you have to check is if the power is actually getting to the systemboard OK. (I’m assuming that the battery may be depleted and non responsive)
Initially inspect the charge port with a strong light and a magnifying glass to check if all the connectors are OK and that there is no lint or debris lodged in the port enclosure, preventing a good connection. If there appears to be an obstruction, do not use a pin or probe to try and get it out as you may damage the connectors. Use a vacuum cleaner instead to try and suck it out. If that fails, gently, very gently try a wooden toothpick to try and dislodge it.
After that you’ll have to open the tablet up and then take a good look to see if there is anything obviously amiss with the circuit boards, connectors etc, e.g. loose connectors, burnt out or cracked components etc.
if everything looks OK then unfortunately it becomes a process of trying to determine firstly if the power supply is OK to the systemboard and then moving on from there.
Without a schematic diagram or service manual this process is extremely difficult for a DIY repair. Authorised Samsung service agents are probably the best bet as they should have access to the service manuals. .
Here’s a link to the ifixit Samsung Galaxy Note 10.1 (2014) guides, which may be of some help, at least to gain access to the internal components.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Hello
After going through your list, I believe the problem is the charging port, I have been having issues with it for a while (needing a cord to be elevated before the device starts charging), I have found sources online to buy a new one and replace it. Thank you for your help.
- de
Añadir tu respuesta
Blake Swensson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 35
Todo El Tiempo: 6,925
