Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Stuck on DFU mode error 4014
Hello all this is my first question on this forum so sorry if i might sound stupid
sometime ago i bought a iphone 6 that suffered a hard fall (surprisingly only the lcd was broken not the glass) i recently replaced the screen. but the device itself is stuck in DFU Mode so far i tried to restore the device on Itunes and 3utools with always the error 4014 on itunes. I quess i the logic board might be damaged do any of u guys have a idea on what i can do? Thnx
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
This will definitely be board level from what you have explain.
Error 4014 could indicate a couple factors like nand baseband and tristar.
The board will need to be assessed and most likely need micro soldering work to be repaired.
There will be a iTunes error log that you can look at although if you're not in the industry may be hard to get your head around.
Hope this helps
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Victor99 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 619
