Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Información de reparación para el Samsung Chromebook Plus. Lanzado en febrero de 2017. Número de modelo: XE513C24.
Replace keyboard on Samsung Chromebook PRO/Plus
I recently spilled liquid on my Chromebook Pro and some of the keys are no longer working. I tried to remove the keys to see if any residue was causing them to not work but to no avail. Is there a DIY to replacing the entire keyboard?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Respuesta Más Útil
This is going to take replacing the entire palmrest, keyboard, track pad assembly for the most painless repair. The assembly usually runs between $50-80 and the repair should take about 30min if you're comfortable with laptop and phone repairs.
Fue útil esta respuesta?
Puntuación 1
You’re better off sending it off to Samsung to deal with this one. Also, isn’t this chromebook quite new? You should check to see if it is still under warranty.
Puntuación 0
Unfortunately it's gen 1 purchased right after it's release date and out of warranty. Thanks for the suggestion though.
Puntuación 0
Añadir tu respuesta
Joe Dellava estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 15
Todo El Tiempo: 1,328
