Saltar al contenido principal
The latest phone in the HTC One line, simply called the HTC 10, released in 2016.
Preguntas 34 Ver todo
Why is the htc not rebooting?
My phone was on 35%battery, put it to charge and it automatically switched off. Several attempts were made to get it powered up but no success.
I tried all the tricks with the toggle buttons, still nothing. The HTC android screen appears…then shuts downs again. The battery sign comes on showing 0% stays for a while then nothing. I tried several different charging cables no change in the phone.
The phone is only 18months old, however i have experienced a bootloop once before.
Any suggestions to fix would be greatly appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario:
I think my phone's got the same issue. it started with some troubles charging and after a while it stopped charging. now its battery is out and it can't charge anymore, the red LED indicator doesn't turn on when I plug it in.
The question is whether it's a battery issue or it's the charging IC and which one needs to be replaced.
- de
Agregar un comentario
2 Respuestas
Try to access recovery mode so we can do a hard reset with the guide below.
https://www.hardreset.info/devices/htc/h...
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I tried both soft and hard reset. Pressed buttons for two and more continuous and the phone never switched on
- de
If the battery is low (under 70%) nothing works anymore. Only external USB power will help. The battery power can drop from 100% to 0% within two clicks, starting an app and the phone shuts down. To fix this: battery replacement…
Puntuación 0
Añadir tu respuesta
Happy camper estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 187
