Saltar al contenido principal
Unidad My Passport de Western Digital. Disco duro externo portátil USB 3.0.
Cannot mount on Mac
My passport was connected to Airport extreme and I got a “Disk needs repair” message. No noise on the hard drive.
Connected the external HD to my Mac but it won’t mount. I tried mounting with `diskutil mount /dev/pathToDisk` and `diskutil mount readOnly /dev/pathToDisk` but it won’t mount. The disk is formatted in the Mac OS Extended (Journaled) format (HFS+).
I downloaded WD Drive Utilities software to check the HD and it passed WD checks.
I am not sure what to do. I cannot loose the data inside the HD (should have had a backup, I know =/) and it doesn’t mount.
Es esta una buena pregunta?
Puntuación 0
3 comentarios
Does Disk Utility even see the drive?
- de
are you getting any kind of error in you mac or any message
- de
Disk Utility sees the Drive, but First Aid fails with error code 8, and mounting via the CLI does not work. No error messages, only when I plug the drive on the Airport extreme, which alerts me the drives need to be fixed.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
I think you’ll need to use a more advanced disk repair app like Drive Genius or your other option is to ship the drive out to a data recovery service like Drive Savers
Hopefully you didn’t use the built-in 256-bit AES Encryption with WD Security software as then you would have no means to recover unless Western Digital has a recovery option which you’ll need to talk with them. WD may also offer a recovery service if the drive is still under warranty so it maybe worth your effort to check that direction first.
Update (09/30/2018)
I’m happy you were able to recovery your files!
I’m not sure I follow your direction here…
The first question: do you have your AirPort on a Surge suppressor or better yet a UPS. The issue is if the AirPort lost power (and via the USB connection the drive as well) so the wink out of power was the cause.
The second question: If this is your backup solution then I would recommend a better drive system. I don’t like one drive solutions as they put your data a risk. I use a RAID 5 solution
If you want to try to salvage your drive I would recommend you do a complete wipe and restore your data. I would still be cautious on depending on it.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Hey Dan. I was fortunate to have formatted it right from the beginning to the HFS+ file system and did not use any encryption. I got another hard drive and I am currently imaging the WD hard drive just in case.
I download software from Ontrack and it seems that it can "fix" my hd, but I am still waiting for the imaging to be complete (it turns out it takes awhile to copy 2TB).
I will check Drive Genius but it seems similar to Ontrack's solution. Thanks for the comments! :D
- de
@danj I ended up going with your suggestion. I bought their Data Rescue software and I was able to recover all files from the hard drive, and keep their folder structure (which was something some other softwares wouldn't do). I wonder if there was a way to "repair" the drive so that I could avoid copying the files over, then formatting the drive that had the logical error, and copying them back.
- de
Añadir tu respuesta
Guilherme estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 6,597
