Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
La Canon Selphy CP910 es una impresora compacta que se conecta a una cámara, computadora y dispositivo móvil a través de una conexión WiFi. Es la 34.ª generación de su tipo en la serie de impresoras Selphy creada por Canon.
My Printer says ink is empty but I have a new one installed.
I have an Selphy CP760 and it continually says that I am out of ink even though I have replaced it 2 times.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
I can not get my selphy 1300 to reg to my phone I had it for a while put it onto tablet but deleted it off tablet now won't register please help
- de Compartir
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Since there is not any answers on this forum yet, I decided to answer it since I found the problem. The problem with this error is that the gear which runs the ink cartridge is missing? I took this device completely aprt and did not find any evidence of that gear anywhere. The motor that runs the cartridge is the smaller of the two.. I looked for a replacement gear for this motor but am unable to locate one. I did use this printer so I know it worked before. So that’s it issue solved sort of..
Fue útil esta respuesta?
Puntuación 1
1 comentario:
How do you get to the gears? I took out 3 screws from bottom but can't get the four tiny ones out!
- de Compartir
Same here. Mine is a CP510, but I have seen the internals of the 7XX series and they are the same, and I have the same problem (it was working some time ago, now it’s not and when disassembling, I saw the missing gear). I am trying to look for a solution, but I think the best is to get another, or just forget about it.
Puntuación 0
1 comentario:
There is a YouTube with instructions. Nbrc north bawly cp760. The part that is broken is the gear on the small motor and the dimensions are 10T 1.48mm hole. It can be bought from the famous Chinese website.
- de Compartir
Añadir tu respuesta
Terry estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 58
Todo El Tiempo: 5,177
