A/c compressor fuses and relay located
On an 88 honda accord where are the fuses for the a/c compressor and the relay for it located on the car
Es esta una buena pregunta?
you’ll have to check Fuse #5 which is the fuse for the clutch relay. The clutch relay should be in the engine compartment on the left fender behind p/s fluid reservoir. There should be two relays. One is for the condensor and the other one for the a/c clutch.. The one with a red wire on the connector is for the AC.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 59
Todo El Tiempo: 4,025
