Saltar al contenido principal
iPhone de 4 pulgadas lanzado en marzo de 2016 con especificaciones de hardware similares al 6s. Disponible en Plata, Gris espacial, Oro u Oro rosa con opciones de almacenamiento de 16/64 GB. Modelos A1662 y A1723.
Preguntas 1055 Ver todo
I saw the connector of battery on iPhone se and 6 and 6s are the same!
So I have a question that if it is possible to replace 6s plus battery to iphone se?
I saw an article that the connector on iphone se is the same with iphone 6,6s,6s plus, even 7 and 7plus too.
and someone tested if they are compatible to each other, and it worked.
If it’s true, se users can replace battery with 6s plus or 7 battery then it can be used better battery capacity? if iPhone se has 6s or 7’s battery?
Thanks mates!
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
5 Respuestas
Solución Elegida
Well, the iPhone SE has the smallest footprint of all those devices so you won’t be able to physically fit anyone of those batteries inside the SE housing. But yes, you can connect them when the phone is opened up and techs do this for testing all the time.
Fue útil esta respuesta?
Puntuación 4
2 comentarios:
To be clear, as per OP's photo, SE and 6S/6+/6S+ are compatible BUT NOT IPHONE 6 (called 6G in the photo). I learned this the hard way just now when I took out my SE battery to troubleshoot my wife's iPhone 6, and could not connect them...
- de
If I connect iphone 6s plus on my iphone se. Will battery timing increase ? ?
- de
It will connect, but physically it would not fit in the phone. And i am unsure if the phone would power up with it connected.
Puntuación 1
1 comentario:
Just trim the battery. Use a scissors. I tried it and it worked perfect.
- de
Will a battery out of a iPhone 7 fes or a iPhone set a iPhone
Puntuación 0
I have a spare iPhone SE battery, is it possible to use it on a 6s?
Puntuación 0
2 comentarios:
Did you figure out?
- de
Did you get an answer for this
- de
I tried this out and it works the iphone SE 1 gen battary works on the iphone 6s and fully functional and the battary health would be the same as if you got it brand new test it out even and it will work for you
Puntuación 0
Añadir tu respuesta
Mango estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 62
Todo El Tiempo: 10,739
