Saltar al contenido principal
Guías para la versión Wi-Fi del iPad Mini 4: modelo A1538. Anunciado el 9 de septiembre de 2015, el iPad Mini 4 es el sucesor del iPad Mini 3.
Preguntas 97 Ver todo
Physically hack-proofing 9.7" and mini iPads
Many organisations with security concerns are sourcing modified wifi-only iPads which can be utilised in high security environments. This requires removing the cameras and microphone. What would be involved in this mod on both mini 4 and ipad 6 models? How long would it take and what tools would be required?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
On the iPad mini 4, just open it up :>). Everything you want to remove is at the top end of the device, the two cameras and the two microphones (just look for the pin holes in the top right corner to locate them). The same would apply to the iPad 6 although the internals are slightly different. Check out the various guides here.
Fue útil esta respuesta?
Puntuación 3
You can set restrictions to disable camera and microphone - but users can re-enable by resetting all settings.
To make them permanently disabled, you need to physically remove them per Minho’s comment.
Puntuación 1
Añadir tu respuesta
Mark Taylor estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 101
