Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
La actualización de marzo de 2015 del MacBook Air de 11" de Apple presenta procesadores Intel Core i5 e i7 de quinta generación, lo que resulta en un rendimiento y vida útil de la batería ligeramente mayores.
Preguntas 116 Ver todo
MacBook Air won’t turn on, freezing, crashing, spinning rainbows
MacBook Air purchased early 2015 won’t turn on,
I get a black screen with the Apple logo and a loading strip which doesn’t load. There is no water damage to the device but the hard drive is full.
Currently need the contents for Uni assessments. Have tried power cycling, SMC? Reset, holding shift, control and alt with the power key, holding command, power and the letters R and P, and holding shift and power which gives me a nearly full loading strip but unfortunately freezes right before success - so frustrating.
I have no tools to open things and I’m hoping to get it repaired before Tuesday (today is Saturday), any ideas welcomed.
TIA MShell
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Do you have access to a second Mac which you can interconnect your system to using Target Disk Mode?
How to use target disk mode to move files to another computer
If you can you should be able to gain access to the files, At least save your stuff. Then reformat the drive and re-install the OS. You should be able to recover your drive.
Fue útil esta respuesta?
Puntuación 0
Comentarios:
Thank you so much
- de
The solid state drive has failed. Will need to replace and reinstall Mac OS
Puntuación 0
Añadir tu respuesta
SD Card estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 96
