Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La tercera generación del Ram fue presentada el 7 de febrero de 2001 en el Salón del Automóvil de Chicago de 2001. Se trató de una importante actualización que incluyó un cuadro totalmente nuevo, suspensión, sistemas de propulsión, interiores y carrocería.
Passenger windows switches don't roll down or up my windows?
All passenger windows switches won't roll down or up only drivers side can make them go up or down??
While rolling either down or up and one of the passengers switch gets pushed it stops the window…?
Es esta una buena pregunta?
Puntuación 0
2 comentarios
The whole passager side won't lock or the window won't go up. Is it the fuse and what color is
- de
I’m having the same problem. But only my drivers window will go down. None of the other will go down from any switch. I have a 2003 dodge ram 1500.
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Hi @ Norman Tate,
It won’t be the fuse.
Here’s the 2005 Dodge Ram wiring diagram (you didn’t state your specific year model but this is within the range selected on this page).
In Sect.8W-60 it shows the the power windows circuits for both the driver and passenger sides and they are both powered by the same fuse (IPM fuse #9) and the Power Window circuit breaker. (see also 8W-13-24)
In Sect.8W-61-3 it shows the door locks are fed by IPM fuse #28.
You would need to need to check the wiring through the driver side door lock/window switch control module to see if it was OK as the power for the passenger side comes through it.
Hopefully this is of some help
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
Could be the window lock switch “WDO LOCK”
It could be faulty or even simply pressed without you knowing.
I hope this helps.
Puntuación 1
If the window lock is not the problem, check your wiring where it goes from the body to the driver’s door. There is a wire from the driver’s window switch to the rest of the switches in that harness. Many times I have found that wire broken or shorted.
Puntuación 0
Añadir tu respuesta
Vettel seb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 46
Todo El Tiempo: 3,123
