Huwawei Y6 Pro keeps shutting down.
Huwawei Y6 Pro - shows the battery at 1% even though it was charged to 80%, (give or take) with another phone. It keeps initiating a 10sec countdown to shutdown every time.
(just a short background) The owner brought the phone to me with empty battery and unable to charge. After probing, he also mentioned that he had possibly wet it, dropped it a few times, and had smelled faint burning plastic and gets quite warm while it is being charged. He further complained that it could only be charged when the charger is inserted in a certain way or when a specific charger was used.
Now I am beginning to be concerned at this point, thinking the fault might be in the battery’s “over discharge protection circuit” that’s telling the system the battery is too low and it needs to shut down. OR
if the main board as a whole is faulty (now replacing it isnt an option as it costs about same as the new unit).
how do I know it’s the over discharge protection circuit? If it is indeed the case, Can I bypass it either via software or a jumper wire?
What other possible issues have I missed?
Update (09/26/2018)
Update:
I used another battery and connected it to the mainboard. It did work just fine and was able to game with it.
The issue though is that as soon as the battery is connected the board heats up hitting about 100°F or 50°C on the thermometer even when the device is turned off. The heat becomes uncomfortable within 15-30 mins.
but then again, the phone works and the battery isnt the issue.
Does someone know what could be wrong and if there’s a possible bypass required.
Es esta una buena pregunta?
