Saltar al contenido principal
El eMac era un Mac de todo en uno basado en el G4 para el mercado de educacion. Fue el último mac en utilizar una pantalla CRT y fue vendido a un precio bajo a escuelas y otras instituciones.
Is my eMac missing a jumper?
I just bought an eMac from a local thrift shop. On the box it said it used European power and came with an Apple European two pronged chord but on the machine itself it says 120V near the serial number and on the bottom access door. When I plug it in to my American outlet and turn it on, nothing happens so I am guessing it is true that it was somehow set to use 220V.
I have been referring to a service manual online, but my computer is a different variation (it is the 1.25 GHz USB 2.0 model). Mine does look the same as the one in the ifixit guide though. I am pretty sure I need a jumper somewhere, but there is only one photo on the ifixit guide of the spot I need to look at, but the spot I need is obscured. Can anyone take a photo of the board (not the logic board, but the huge circuit board under the CRT) where the power cable connects? I’m referring to the spot in the guide where the blue and brown wires from the power socket connect to the board with a white plug. If you’re looking at the eMac from the top front, its to the left of the CRT neck.
Here is what mine looks like:
Thanks!
Es esta una buena pregunta?
Puntuación 2
2 comentarios
@nabru50 give us all the numbers from the back of your eMac so we can determine exactly what model you have.
- de
Model No: A1002
G4-1.25GHz/256/40/Combo/56K/110V
100-120VAC,3.5A,50-60HZ
- de
Agregar un comentario
1 Respuesta
Solución Elegida
@nabru50
it will work much better if you post some pictures of what you are looking for. that way we do not need to guess. this is the information I got:
Table 1: Jumper Settings
Voltage / Voltage Jumper /LHR Jumper
110 V /Jumper is on /Jumper is on
220 V /Jumper is off /jumper is on
220 V /Jumper is off /Jumper is off, LHR module installed
with LHR module
Fue útil esta respuesta?
Puntuación 3
12 comentarios:
This does look like mine. I am missing the voltage jumper with 2 pins. Any idea where I could get one?
- de
@nabru50 P902? I would just temporarily try with a cable with alligator clips. See what happens
- de
That did it. It still wouldn't work at first, but I pressed the power button multiple times and it eventually kicks on after 2-3 presses. Thanks!
- de
May I please use this thread to ask a question about a US eMac (110V 60Hz) which I want to use in Singapore (220V 50Hz)? If I remove the above-mentioned Voltage jumper, should I be able to plug in directly to 220V?
- de
US 110V eMacs do not have LHR installed by default. So, hopefully, I do need to remove the LHR jumper.
- de
Mostrar 7 comentarios más
Añadir tu respuesta
Phillip Urban estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 322
