Why won’t my car start
I have a 98 Chevy Malibu yesterday I changed the battery and fluids and the car wanted to start but didn’t so today I replaced the spark plugs and now the car won’t even turn on why is that?
Es esta una buena pregunta?
J De did the car work when you started or was it in a no start condition before you started replacing parts ? If it hasn’t been running how long has it been since it last ran ? Is the battery you replaced it with new? Was it fully charged . Do you have a multi meter . If so test the battery , it should have at least 12.6 volts to start the car . Check your battery connections . Start with the obvious and make sure your connected correctly negative to ground(Black) positive to power(Red). If you have a slow crank situation check the connection at the ground on the car to frame and the connection at the battery . If you have good power at the battery and good clean connections at the starter and grounds then try replacing the starter. Start with these suggestions and then let use know whats up . A little more info on the car as to what state it was in when you started working on it would be helpful .
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 684
