Refuses to turn on
For some reason my X20 will not simply turn on. I have charged the battery still nothing Help please
Es esta una buena pregunta?
Have you tried pressing the play button to turn it on?
Fue útil esta respuesta?
Hello Andrew 6, I have same problem and when I press play button it starts playing the photos but the switch is of. If I switch on it will not do anything, could it be this fuse? Thanks in advance
I’ve had exactly the same problem on my X20. I followed the disassembly guide and traced the fault to a blown fuse on the main board, a tiny SMD fuse in 0603 package. I believe this is rated at 2.5A. I’m going to replace it and if it works I will add a replacement guide. Hopefully there are no follow-up faults.
I’ve replaced the fuse on the PCB and reassembled the camera - it is working absolutely fine now! I've added steps to the disassembly guide to show where the fuse is located.
Where is this fuse located? Is thid fuse easily available?
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 24
Todo El Tiempo: 647
