Saltar al contenido principal
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
Preguntas 30 Ver todo
Why one of my propeller not working?
I have a DX-2 stunt drone. one day it fell from 10 feet fall to the grass. Then one of the propeller stop working I was surprise because it survive alot worst crashes. what should i do? i just want to know if i can fix it before i got buy a new one.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 9
5 comentarios
Did you ever get an answer? I have one doing the same thing. New motor doesn't fix. Same issue
- de
my one of my propeller does not want to start on my dx-2 stund drone
- de
my propeller won't work and the wings are too hard to fit on there they are a little too small to fit.
- de
same problem and im pritty sure it is because one of the motors died out and I'm trying to fix it so I took off the propellers and felt the tip of the motor and it seems it's borken and I need a new motor or drone
- de
or cricket bord or wires
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
you may need to order a rotor replacement for the drone, look at the manual for details where to get one
Fue útil esta respuesta?
Puntuación 3
mabey get either a new motor or take the blade off and put back on and then try
Puntuación 1
it is because you either need a new motor or you just need to put on new propellers if that does not work, sorry just keep looking.
Puntuación 1
2 comentarios:
The reason why you need to add a new propeller is because when the wing is cut on something but the motor is still spinning it will smooth it out so it has no grip on the wing.
- de
i believe this to be true. My grandson got his for xmas a day ago and can't use it already. i feel that the motor is functioning but the blade to shaft connection isn't secured.
- de
Yeah its something with the connection from motor to blade. Like a gear slipped. I am trying to find something that illustrates the inside and how to open it
Puntuación 1
Añadir tu respuesta
Majur GonZolaz estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 21
Ultimos 30 días: 107
Todo El Tiempo: 6,354
