Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
The Ram line was redesigned for the 1994 model year. Development on a second generation began in 1986, ending in late 1992.
Computer malfunction, reset possible?
The main snap together wiring was removed while the engine was running. Now runs super retarded. can I reset?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
With the engine off, cycle the ignition on and off 3 times quickly leaving the ignition on the last time. The odometer will display the codes in the PCM. f the codes are not active you may be able to clear them with the odometer reset button. If this does not work you will need a OBD scan tool to clear the codes.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Jack Heringer estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 45
Todo El Tiempo: 500
