Saltar al contenido principal
Modelo A1059 o A1099 / disco duro de 20, 40 o 60 GB / rueda de clic sensible al tacto
Preguntas 20 Ver todo
Enclosure for iPod classic hard drive
Power source for iPod Photo 4th Gen (60gbs) died. I tried replacing battery but no joy.
Is there an enclosure or adapter o can use to transfer songs off the drive and then format as either a portable hard drive or as additional storage on a Mac Pro?
James C.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Solución Elegida
You can access this ZIF drive using a Universal Adapter:
Universal Drive Adapter
Imagen de Turn your current hard drive into an external drive with this adapter.
Producto
$24.99
Fue útil esta respuesta?
Puntuación 3
It may be the hard drive which has failed. If so your out of luck. You can still get some use out of it with this cheap fix
Puntuación 0
1 comentario:
Avais -
Thank you for your reply and attached solution. I was assured by the guy that diagnosed my iPod that the drive was fine, it is just the power module is defunct.
Regards,
James
- de
This is exactly what you need: ZIF HDD caddy: https://amzn.to/42furqD
Puntuación 0
Añadir tu respuesta
James Coogan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 524
