Saltar al contenido principal
Repair guides and support for LED, LCD, HD and other Vizio TVs.
Preguntas 931 Ver todo
Dark t-shaped lines on left side of screen.
We bought a 55" vizio m55-c2 led tv a couple of years ago. Recently, sideways black t-shaped dark lines will randomly appear & stay. We can turn off the tv for a few seconds or minutes & the picture is fine. Randomly the bars come back - various timing. Any ideas what this could be & can it be fixed?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The random appearance and "reset" fix suggest that this is heat related and is probably centered on the Tcon board. Please try to upload a picture of the problem and note when this happens. You may see a pattern of when this happens.
Please keep us posted.
Dan
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I will stand somewhat corrected. From the picture, I would be looking at the LED strips behind the panel. I believe that there may be a few LEDs that are starting to fail. These strips are usually connected in series which means that if one fails, the strip will fail. Based upon the pattern of darkness, I believe that a few strips are cutting out. Since the set recovers, it may be as simple as a poor connection somewhere on the strips themselves or at the connector to the strips.
- de
Añadir tu respuesta
Daisy May estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 293
