I can't log in. I get 'incorrect password" and cursor is gone,
Suddenly my password is getting the response of "incorrect password" and my cursor has disappeared and the mouse pad is not functioning
Es esta una buena pregunta?
Do you have a virus? have you done anything uhh lets just say risky recently, pirated games? if not get back to me and I'll help you out to your next step try these general tips from microsoft:
Method 1:
Run the fixit available in the link below and check if that makes any difference
Hardware devices are not working or are not detected in Windows
http://support.microsoft.com/mats/hardwa...
Method 2:
Perform Clean Boot and check.
To help troubleshoot error message, you can start Windows Vista or Windows 7 by using a minimal set of drivers and startup programs. This kind of startup is known as a "clean boot." A clean boot helps eliminate software conflicts.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
Please note: After the troubleshooting, make sure to boot your computer to normal mode by following the step 7.
Method 3:
Step 1:
Check keyboard works fine with on-screen keyboard.
http://windows.microsoft.com/en-US/windo...
You can also check whether issue is in keyboard or not by connecting external keyboard.
Step 2:
Update mouse driver
a.Click Start.
b.Click Control Panel.
a.Using the drop-down menu next to View by: in the upper-right corner, select Large Icons.
b.Click Mouse.
c.Click on Hardware tab, Click on Properties button.
d.Click on Driver tab, Click on Update Driver.
IF NONE OF THESE WORK GET BACK TO ME.... YOU MAY HAVE TO REINSTALL WINDOWS
Fue útil esta respuesta?
I forgot password and cant log in how can i get in and enter a new password?
Can anyone help me unlock my Acer Aspire one Cloudbook 14 forgot my password cant log into it!!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 18
Todo El Tiempo: 331
- try resetting your laptop ???
- It could be a keyboard problem
- de Luis Anniel
Hi,
Try plugging in a USB keyboard and see if it works OK.
- de jayeff
Thanks! I'll try that.
- de kenneth smoke
