How do I reinstall the focal cap?
can not get the focal cap back on, Do push the cap in and turn counter clockwise, how do you line up the cap so you can push it in?
Es esta una buena pregunta?
davepridgeon check this guide Disassembling Optoma HD20 Cover
This is the official disassembly order so it should be in opposite order to reassemble:
1. Rotate Focus Ring by anti-clockwise to the end (as red arrow). Push against
projector lens so as to pull out the Focus Ring.
2. Then take off Focus Ring carefully.
'''Note: When you assemble the Focus Ring, ensure the three card slot (as red circle) stuck in the double-screw bolt ( as blue square) properly, then the focus ring can be well adjusted.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 142
