Cause 1
Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Evaporator Fan Motor for your Refrigerator
RepairClinic Item #1089
Refrigerator evaporator fan motor assembly. This motor circulates air between the freezer and refrigerator compartments. If defective, the freezer will be cold, but the refrigerator section will not cool properly.
$60.34
Quantity:
In Stock ›
Suggested toolsMulti ScrewdriverRepairClinic Item #3527472$15.25
Same Day ShippingOrder by 8:00 PM ET, this part ships TODAY!
365-Day Return PolicyReturn any item for any reason within 365 days of placing your order.Find out more »
Total: $60.34
Cause 2
Temperature Control Thermostat
The temperature control thermostat directs voltage to the compressor, evaporator fan motor, and condenser fan motor (if applicable). If the temperature control thermostat is not working properly, it may prevent the refrigerant system from running. To determine if the thermostat is defective, rotate the thermostat from the lowest setting to the highest setting and listen for a click. If the thermostat clicks, it is not likely defective. If the thermostat does not click, use a multimeter to test the thermostat for continuity. If the temperature control thermostat does not have continuity at any setting, replace it.
Parts
Temperature Control Thermostat for your Refrigerator
RepairClinic Item #223393
Temperature control thermostat assembly
$74.24
Quantity:
In Stock ›
Total: $74.24
https://www.repairclinic.com/RepairHelp/...
1 comentario
My freezer coils are freezing up in the middle of the coils
- de Gary Gautreau
