Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Pantalla de 7.9 pulgadas / Modelo A1432 / Disponible en blanco o negro / Anunciado el 23 de octubre de 2012/16, 32 o 64 GB de capacidad
Slight Screen Repair Issue
Hey there I was attempting to take the digitizer off my badly shattered iPad Mini 1 Space Grey and it was cracked so badly there are still chunks on it in really tiny pieces any ways I can save it so I can successfully put the new digitizer and LCD in thank
Ps if you can’t visualize I can add a photo
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
You'll have to scrape them off, with some form of flat tool. Try putting some IPA or Acetone on them first to soften up the adhesive. Once that is done, you'll want to remove all of the adhesive from the frame (use IPA/Acetone again) before putting the replacement digitizer back on.
Some replacement digitizers have poor quality adhesive pre-installed so you may want to consider applying a high quality adhesive such as this one.
Imagen de Custom cut rolls of Tesa 61395 double-sided tape for repair.
Producto
Tesa 61395 Tape
$8.95
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thanks I’ll try that ipa has solved so many issues before
- de
Añadir tu respuesta
Ben Cybulski estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 81
