Saltar al contenido principal
En junio de 2017, Apple actualizó su MacBook Air de 13" con un procesador Broadwell Intel Core i5 más nuevo, lo que resultó en un rendimiento y vida útil de la batería ligeramente mayores.
Preguntas 423 Ver todo
Topcase exchange US -> EUROPEAN
Hi everybody.
Can anybody tell me how to sync a A1466 logicboard with the Topcase. Changed the topcase from US layout to european Topcase, but left Shift Key is not working.
Already tried several steps (Internet recovery, SSD from european version with OSX pre installed) but nothing solved the issue. :-/
I'm not able to change the layout from US (10 Keys between left and right shift key) to european layout (11 Keys between left and right shift key)
Thanks in advance,
Ben
Es esta una buena pregunta?
Puntuación 0
2 comentarios
@littlebigb - Did you also switch-out the trackpad or did you reuse the one from the original uppercase?
- de
Hi Dan,
Yes, I reuse the one from the original uppercas.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
If you have performed all software tweaks found in system preferences/keyboard to no avail try resetting SMC: turn off the Mac, press shift+ctrl+alt+power..you'll see magsafe light going from amber to green and amber again. Boot the Mac and before the chime press alt+cmd+P+R and keep them pressed until the second chime to reset Pram. If no joy, try reseating the keyboard cable on the logic board.
If none of these work, possibly you got a faulty topcase.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
+1 vote for faulty topcase if SMC reset does not help.. though I feel I might be missing something..
- de
Thanks. I'll try it tonight. :-)
- de
Añadir tu respuesta
Little Big B estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 102
