Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1687 / A1634. La Reparación de este dispositivo es similar a las generaciones anteriores, requiriendo destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16, 64 o 128 GB / Silver, Gold, Space Grey o Rose Gold.
Preguntas 1041 Ver todo
Killing batterys unexpected shutdown at around 50%
Hi I have a iPhone 6s plus that I have had to replace battery around 8 times as the battery works fine for around a month then dies at 50% like its flat pug it in I get 50% than continues till the battery is completely drained replace battery then like new for another month it's be like this since it was stolen from me and I got it back smashed now I'm about to replace the U2 Ic but I want to no if anyone knows of any other chips that can cause this so I can repair
Update (06/29/2018)
Hi again I'm really stuck with this one I have replaced Tigris Ic mosfet ic tristar ic I'm unsure if it's fixed the shutdown issue yet but in addition to that I have released its going through power like nothing one hour YouTube video used about 30% so I looked at big pmic and found caps c2016 c2013 c2017 c2020 c2014 c2015 c2019 and c2021 all to be shorted can anyone help with this issue as I'm sick all I can think of it replace the pmic and no sines of water damage or corrosion gave it a ultrasonic bath
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
In addition to replacing the U2 IC, I would recommend inspecting the board under a microscope to look for corrosion or deposits (as a result of water damage) that could be shorting out connections, this would lead to excess battery drain. If there is corrosion/deposits from water damage, the first thing I would recommend is a good cleaning.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
dylanrichter44 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 118
