Saltar al contenido principal
Modelo A1059 o A1099 / disco duro de 20, 40 o 60 GB / rueda de clic sensible al tacto
Dark Screen with Flickering Lines, Otherwise Works Fine
Hello, I have the HP Edition 20 gb Ipod 4th generation, model # MP102. Previous to this issue, I had replaced the hard drive inside it with compact flash solution at 64 gb, replaced the battery, hold switch assembly, and, in trying to fix the issue, replaced the screen. It had worked fairly well and easily for about a year prior to this issue arising.
As for the issue itself, it's as described in the title. The screen commonly boots into a black square, which renders it unusable. If it does not do this, visible flickering lines appear regularly in any moving image on the screen.
I've attempted several ways to fix the issue; none have seemed to work. First, I replaced the screen as mentioned earlier. Then, I attempted to clean the inside and the logic board with isopropyl alcohol, although I honestly had no idea what to look for when doing so. The iPod had not been exposed to any liquid at all in the year I'd had it. I also tried to restore it twice, but each time the issue would reappear as soon as I turned it on.
My assumption is that the logic board is fried. Anyone who has had similar issues, or who knows more about this issue, your help would be much appreciated. Thank you!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Try wiggling or reseating the bracket and connector between the display and the logic board.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Will be trying this, thank you for the suggestion. I'll update you on whether it works or not in a few minutes.
- de
Update: I now have no idea as to whether or not that would work, and won't for quite a while. While trying to reseat it, I took out my zif to cf adapter from the hard drive cable. To my surprise, two of the pins on the very right side were entirely bent out of shape and one was still left inside the adapter. I suspect that was the true source of my problems.
- de
Añadir tu respuesta
Ben H estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 67
