Keyboard with water damage
My keyboard got wet and now a few keys are not working. Is the keyboard for the XPS replaceable?
Es esta una buena pregunta?
@gts112009 yes it is but a bit of a PITA. Download the maintenance manual from here Page 77 will show you how to do it. 30 Philips screws keep the keyboard attached to the palm-rest assembly (basically your top case)
Fue útil esta respuesta?
Before you replace the keyboard, check the Keyboard Control Board. This is just under the battery, removal is described in the manual.
I had water damage, replaced the keyboard which was a PITA, to then find out that is was the contacts on one of the sockets on the Keyboard Control Board that had failed.
Hope the helps someone!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 1,067
