Saltar al contenido principal
Fourth generation Honda Civic
car turns on but when given gas dies. engine light on.
Recently got my car fixed by replacing the ignition switch. in the last couple of weeks i have also replaced spark plugs, wires, rotor cap and rotor along with the Fuel filter. it has been driving and idling pretty ruff and as of today driving it home i was giving it gas to where it felt like it had no power till i finally came to the point of my gas pedal all the way to the ground with the check engine light ON it didn't t wanting to go anywhere at this point. i was lucky enough the side road opened up to where i wasn't stuck in the middle of the road. i ended up getting it towed home . car starts up but wants to die.
91 civic wagon , Auto
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Have the timing checked . Its probably the timing belt has stretched or slipped . Honda timing belts should be replaced every 60,000 to 100,000 miles. depending on how you drive . Hope this helps
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
sandyperaza estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 173
