Where is the windshield washer pump located
The pump is not located in the wheel well. Not located in front of the windshield under cover with wipers. Where is it ?????
Es esta una buena pregunta?
What year is you jeep? Most washer pumps are located on the bottom of the washer fluid reservoir so find the reservoir and look to the very bottom . If its not there then follow the lines that come out till you find the pump it has to be in the lines somewhere . Hope this helps
Fue útil esta respuesta?
Mine was located in the reservoir and the reservoir is located in the driver side wheel well
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 570
