Saltar al contenido principal
La Nikon Coolpix L32 es una cámara digital lanzada en 2015 por Nikon Corporation.
Preguntas 13 Ver todo
Why is it turning off to prevent overheating?
My nikon Coolpix l31 is turning off to prevent overheating in under 30 seconds of having turned it on. This started about a week after I got it. Haven't used it much since, got it about 2 years ago.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
the likely answer is one of two things. A short on the board, or a bad internal resistance of the battery. If you replace the battery, and it doesnt fix the issue, the most likely scenario is that a board level short is drawing too much current. replacing a logic board is usually not worth the cost of the repair, and i would suggest replacing the device at that point.
Fue útil esta respuesta?
Puntuación 0
Nikon l31 modal overhiting problem
Puntuación 0
Añadir tu respuesta
Kole White estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 972
