Saltar al contenido principal
Guías de reparación y desmontaje de la línea de smartphones Huawei Honor.
Touchscreen fully works for 10-30 min then fails partially
I have an Huawei Y6 SCL-L03 (Honor 4A), it works completely fine for around 10-30 min but then the touchscreen stops working, after pressing two time the power button (Turning off and then back on the screen), a part of the screen stops working, like a little bar in the middle of the glass, but only that little section stops working.
To make it to work again, I have to turn off the device, wait a few hours, then turning it on again and the cycle repeats itself again and again.
What I already did was cleaning the pins and connector from the digitizer with alcohol (It works with a cheap-ass tablet I had) but no luck.
Pd: I can upload a video later on the behavior of this issue, if it helps.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Although i havent worked on Huawei phones before, as a general rule issues where a screen works for a while and then stops means the circuit in the lcd itself is bad and it needs a new screen. I cant guarantee this is the issue, but hopefully this helps you get a little closer to a solution.
Update (06/03/2018)
Apologies. I read that wrong. I thought you said lcd. If u tried cleaning the connection off then you probably need a new digitizer unfortunately
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Noah estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 75
