Why will my roller not stay on?
The rug cleaner roller will come on but will not stay on for more than 30 seconds. The roller is clean, the belt is fine. The switch seems to be working. What could my problem be?
Es esta una buena pregunta?
Rep: 11
Hi P. Taylor! The first thing that I would think to check would be the motor and if that is actually powering the belt. The next thing I would check would be to see if the belt is tight enough to consistently activate the roller as it may look good, but could be stretched.
Comentarios:
The motor to the roller actually shuts down but the vacuum motor stays strong. How would I differentiate between the vacuum motor and the motor running the roller, is there some trick?. It runs fine for 30 seconds then stops. The belt was changed so this is not the issue. Thank you for your answer.
- de P. Taylor
I would watch this short video showing how to troubleshoot your specific vacuum if the roller isn't working. I hope this helps! https://www.youtube.com/watch?v=EgJb6np-...
- de Noah Jones
Thanks, that video is elementary not my problem. If I bypass the circuit board in the vacuum head it will run and maintain running. Other than activating the roller switch is there anything else I should know that this circuit board does?
- de P. Taylor
Did you ever get it fixed? This is the exact same problem I’m having
- de Lacey Potter
I have the exact same problem as well. Roller comes in for. Few seconds and then stops.
- de Martin Goen
I think my air pro developed this problem. The roller is supposed to automatically engage when you recline the vacuum. My vacuum will only engage the brushroller if I recline the vacuum barely an inch or two, any lower and it instantly shuts off. It was almost impossible to vacuum in this weird upright position so I’m looking for a fix. I feel like the problem is somewhere low around the steerable neck area, like a sensor is giving a false reading. If i find an answer i’ll let you know.
Rep: 1
I purchased belt, part number listed in Manual and replaced belt but it is too long and will not run the roller. Anyone else have this problem?
Rep: 1
This thing is stupid by a new vacuum on wayfair
Rep: 1
I’m having the same problem - since its last service actually, when they replaced/upgraded parts. Spend more time cleaning it than using it effectively. Ready to throw it away now.
It is worse on carpet than tiles, but does it there too.
Ultimas 24 horas: 3
Ultimos 7 días: 33
Ultimos 30 días: 155
Todo El Tiempo: 3,819
