My Honda wont start
I have replaced the starter but it sill wont start, the starter spins but does not engage
Es esta una buena pregunta?
Your timing may be out. Or maybe there is an electrical problem preventing power from getting to the distributor. Hook your timing light to wire #1 and turn the key to on, so that the starter will turn. You should get flashes from the light. And you can check the timing in this way. If the timing is badly out, it will never start. But if you are getting flashes on the timing light, you will at least know that the distributor is getting power.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 52
