Saltar al contenido principal
The Huawei P8 Lite (Model: ALE-L21) announced April 2015, shows beauty in simplicity. Its professional cameras enable you to take natural and sharp pictures even in the darkest environment. The beauty mode highlights the best features of the owner in every selfie.
Preguntas 20 Ver todo
phone turned off and not turning back on
My phone Huawei P8 Lite was working totally fine but suddenly turned off and now it's not turning back on. phone was not out of charge when it died and now, as I plug in the charger, after a while it gets warmer meaning (i think) battery is still charged but its neither turning on nor showing any screen.
Any help would highly be appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Try to Hard Reset your device by following these steps:
1. Remove the battery and wait for a while
2. Meanwhile, you can remove your SD card as well
3. Plug the battery again
4. Hold the “Volume up” and Power button simultaneously.
5. Select “Factory reset” option by using the Volume up and down keys
6. Validate your option with the power button
If the phone has gone into “hard-freeze”
This can often happen with Android. Simply remove the battery (if applicable) and long press the power button for another 30 seconds.
Reinstall firmware
If nothing else seems to function and you are not able to figure out how to fix a Huawei phone that won’t turn on, then consider reinstalling the firmware.
Fue útil esta respuesta?
Puntuación 1
5 comentarios:
But, the battery is non-removable.
I already tried holding power button for 30 seconds, wasn't helpful.
- de
same....dont know how to realive it
- de
Hi my p9 lite switch off when it comes to the Huawei logo
- de
My phone battery cannot be removed. I already tried holding power button and increase volume button at the same for 30 seconds and it's not working. what else can i do now
- de
- de
My phone can charge but the screen blank
Puntuación 1
1 comentario:
Change the screen if not work u have a backlight or data problem
- de
Añadir tu respuesta
Syed Hamza Ali estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 8,368
