Saltar al contenido principal
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
Preguntas 369 Ver todo
G935F FRP bypass , stuck on downgrade
Hello, i have g935f s7 edge with FRP, downgrade with odin not possile, stuck on error sw rev check device 2 binary 1... also realterm not work, bluetooth headset not work... i think is 2018 security patch..
some ideas pls? :/
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
5 Respuestas
Respuesta Más Útil
You can use latest method to bypass FRP lock from your phone very easily. Just check out here: https://www.bypassfrpfiles.com/2018/11/b...
If you need any tool you can check out here as well: shorturl.at/avIP8
Fue útil esta respuesta?
Puntuación 1
are you looking for Bypass FRP Samsung Galaxy S7 Edge? If so, then you are in the right
'''Bypass FRP Samsung S7 Edge – All Methods'''
Puntuación 1
just flash any 6.0 firmware only select boot system recovery
Puntuación 0
1 comentario:
Great! And how do I do that?
- de
You can bypass frp galaxy S7 and Galaxy S7 edge using most latest 2019 frp bypass method. In this method you don’t need to go through (Add Call | Talkback | PC | FLASH ).
This is very easy method to bypass frp lock using 2019 frp method.
'''Click here to unlock Samsung Galaxy S7 edge & Galaxy S7 FRP.'''
Puntuación 0
you try flash firmware latest version and FRP WITHOUT PC
Puntuación 0
Añadir tu respuesta
VojTech estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 23
Todo El Tiempo: 2,622
