Saltar al contenido principal
Laptop ultrabook HP Envy 4-1030us. Lanzado el 15 de julio de 2012, Producto No. B5T04UA. Caracterizado por su perfil delgado, el sistema viene en varios colores.
Preguntas 2 Ver todo
How to fix broken backing from hinge?
So my HP Envy Laptop won't close or open with both hinges. The hinge itself is fine, the piece holding the hinge to the back of the screen is not- as in the hinge is still screwed into ta piece of plastic, but the plastic broke away. I have tried hot glue and super glue, but it still came apart.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
HI:
You can find a cover on ebay at varying prices depends on what they are including with the cover.
Or you can drill thru and put small machine screws and washers thru, file them flat and add some tape ot goo to keep from catching on things.
Good luck
Alton
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Josh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 319
