Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Xbox 360 es la segunda consola de juegos fabricada por Microsoft y se lanzó el 22 de noviembre de 2005.
Xbox error codes
Does anyone have a cut-sheet for Xbox 360 Pro or later with error codes, problems, and their solutions? I am new to 360's and am looking for any information available. I am aware of Iprep 101 but have not used it. Any information would be helpful.
Also, I am very experienced with repairing iPods - so I'm happy to share my experience with anyone - just ask.
Thanks,
Kelly
Es esta una buena pregunta?
Puntuación 5
5 comentarios
Thank you Brian.
- de
Accept Brian's answer if it answers the question!
- de
Brian's answer was better than nothing and has been helpful. Darn Interns! LOL
- de
There is an Accept answer button on Brian's answer. If this answered the question, you should select it to give him credit. Also, try to keep answers away from email, and here on the site, so everyone can benefit. Thanks!
- de
sedric, thanks for your help. I will give Brian the credit - still learning the process. However, I want to use my email for documents not for answers. But good advise as well.
- de
Agregar un comentario
6 Respuestas
Solución Elegida
A quick search turned up this sheet which seems fairly comprehensive.
Fue útil esta respuesta?
Puntuación 4
Firstly error codes follow the link below its pretty comprehensive.
http://www.llamma.com/xbox360/repair/Xbo...
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Firstly try a new AV cable. Secondly the Hana or ANA chip does sometimes develop dry joints, taking a thin tipped soldering iron to the pins of the device is the only solution to that. If its the graphics chip causing the error you could either try the X-clamp solution (google it) or you could try getting it re-flowed... whatever you do dont wrap your 360 up in a towel or take a paintstripper heatgun to it in order to try and reflow the graphics chip (You will damage the chip internally if you do so ;) ) Easy way to tell if your graphics chip is at fault is to open up your 360 and apply downward pressure to the graphics chip when turning on your 360.
Best of Luck
Justin
ConsoleFixers.com
Puntuación 1
I hope REpair dudes aren,t using this website to blackmail family owned video stores.
Puntuación 0
Does anyone know about the E74 error code for Xbox, and how to fix it?
Puntuación 0
huawei network line err u8950d
Puntuación 0
This came super late but it is verifiably the most accurate error code table.
https://repair.wiki/w/Xbox_360
Puntuación 0
Añadir tu respuesta
aquabluekt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 45
Todo El Tiempo: 11,076
