Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Model 917 Differential Problem
Tractor, YTS4000, 24hp 6 speed manual-- has difficulty turning. To me it seems the differential is locked as the front wheels continue to want to plow forward while turning. (This is not a "steering" problem as the front wheels turn fine) What I see: This winter when using the snow blower as I attempted to turn right, the right rear wheel was spinning!
Es esta una buena pregunta?
Puntuación 0
1 comentario
You are 100% correct. It thinks it is a drag-racer with 'posi-track' !
- de
Agregar un comentario
2 Respuestas
Solución Elegida
@tlien this mower uses a transaxle. See if you can find a tag or manufacturers number on it. If there is none check the attached image for an ID and let us know if there is a match.
This is not an answer but the only way to post an image. I shall delete it once I have clarification from the OP No reason to downvote it yet ;-)
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Need to replace the two Drive belts on a 42-in craftsman motor
- de
Respuesta Más Útil
If you're a 'shade-tree-mechanic', you can save a few bucks by removing the unit, and take it to the shop for repair. Or, fix it yourself. These machines were not known for their longevity, plus differentials are expen$ive, so I would make it a D.I.Y. project.
Puntuación 1
Añadir tu respuesta
Terrence Lien estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 438
