Saltar al contenido principal
Una lavadora de Maytag con una tasa baja de satisfacción del cliente y una tasa alta de fallas.
Leaking water on the bottom
I Took the back cover off I ran the washer empty and there was no water leak .then ran with a load and there was water leaking . I seen the water dripping frim the bottom in spots but couldn’t tell where it was leaking from. Where would the leak be coming from and how do I fix ( you tube i’m Sure ) please and thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
2 comentarios
Maytag washer ,bravos xl leaks from bottom what could be wrong.
- de
My maytag leaking from bottom when it on spin
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Cause 1
Drain Pump
The drain pump pumps water out the drain hose. If the drain pump is cracked or damaged, or if the bearings are worn out, the drain pump may leak water. The drain pump is not repairable—if the pump is leaking water, replace it.
Cause 2
Tub Seal and Bearing Kit
The tub seal might be torn, causing water to leak from the seal. If the tub seal is leaking water, water may leak through the tub seal and into the tub bearings. This can cause the bearings to fail. For this reason, if the tub seal is leaking water, replace both the tub seal and the tub bearings. Be aware that this is a complicated repair and will require disassembling most of the washer.
Cause 3
Tub Seal
Fue útil esta respuesta?
Puntuación 5
Our Maytag washer was leaking intermittently. Checked all the above mention spots for leaks and found none. Found there is a siphon break on the pump discharge where it goes through the back panel that was not always sealing properly when under pressure. Cleaned it of lint with a tooth pick and blew water through it until it would seal when sucked on. It now seals properly
Puntuación 2
1 comentario:
Can u please specify where the siphon break is on the discharge pump? Do u have a photo of that?
- de
Añadir tu respuesta
Ryan Buil estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 8
Ultimos 30 días: 39
Todo El Tiempo: 38,021
