Engine leak oil also blows back oil from the dip stick
My car has an oil leak. It also blows back oil through the dip stick
Es esta una buena pregunta?
Sounds like your PCV valve needs replacing.
Fue útil esta respuesta?
mike vernon possibly blown piston rings. Check or replace your PCV valve as suggested and then do a leak down test. It will tell you a bit more about what is going on with your Camry
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 57
