Can I add more RAM to an Early 2015 MacBook Air?
I just bought a used Early 2015 MacBook Air with 4GB of RAM. Can I upgrade it to 8GB?
Es esta una buena pregunta?
Hi Scollay,
According to this picture, the RAM is soldered onto the same board with the flash memory. It would not be easy to replace the RAM only.
Hope that helps!
Fue útil esta respuesta?
As @arthurshi stated, the MacBook Air systems all have soldered RAM.
You could swap out the logic board with one that has more RAM. Review this guide which lists the different boards: Reemplazo de la placa lógica del MacBook Air 13" de principios del 2015.
Ultimas 24 horas: 4
Ultimos 7 días: 26
Ultimos 30 días: 89
Todo El Tiempo: 9,408
