Saltar al contenido principal
Un teléfono inteligente Android de Samsung para el mercado asiático, conocido por muchos números de modelo, lanzado en diciembre de 2014.
Preguntas 117 Ver todo
Can I turn my phone to back up data
I have Galaxy A5 2017 and i think the charger port is broken it does not charge, the past few days it was hard to find a spot to start charging and now it does not charge at all ,but i have really important files on the phone and can i turn it on in some other way just for a few minutes to back up the files before i take it to service? Thank you in advance
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Do you have another samsung at all that you could connect your battery up to and charge it? Obviously you'll have to line the gold pins up on the battery but it will charge, otherwise you could take it to a repair store and just ask them to charge it for you? Thats a service i offer so i'll assume most are the same.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
@will91491 this will only work if she has an exact 2015 Samsung A5. All Samsungs are built from the ground up and all use different batteries. Also, this requires disassembling the phone. If you were going to to do this on an A5, you might as well repair/replace the chargeport!
- de
Añadir tu respuesta
Samsung galaxy a5 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 35
