Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
iPhone 6 Touch screen not working after water damage.
Long story short, my phone got water damage and wouldn't turn on, I bathed the Logic Board in alcohol and put it back together and now it works, with a catch.
My LCD screen is working, some diagonal lines and the brightness might be a bit lower (I cant remember if I set it low.) And a brighter section in the top right of the screen.
However the biggest issue is the touch screen isn't working should I buy a new screen or is there some other fix I should try before this.
Thanks!
EDIT: Looks like I fixed the touchscreen myself, only thing is the right side of the screen doesn't work so it looks like I will be buying a new screen after all.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Just to follow-up on your previous question and now this one, yes, I would try a new screen. If the problem doesn't go away, they you may have a problem with the Touch circuit on the logic board, which would require a micro-soldering repair.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Matt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,459
