iPhone 6 no longer turns on.
Hello,
Just a few days ago my phone turned off randomly. The phone did not drop and was working fine previously. I put it in charge with no sign of life. Magically after an hour it turns on. Then it turns off again. I put it in charge again with very little sign of life. The apple logo comes on but turns off right after. This happened a couple times but it has been a few days now and the iPhone does not turn on. At all.
Just some FYI.
Previous repairs? NON OEM screen and battery. ( My guess its the battery? )
When did I replace those parts? About a couple months ago.
iTunes does not recognize device.
No water damage.
New screen did not help.
I see no damage on the logic board or connectors. ( At least to my eye )
Holding onto the power and home button did not help.
Anything helps!
Thank you in advance.
Es esta una buena pregunta?
2 comentarios
Well seeing as you replaced the battery only a few months ago, it's unlikely that the battery is causing the problem (At least it's definently not the problem if it's done by a repair shop, whom always guarantee that it works)
Have you tried inserting it into a pc and see if iTunes can recognize it?
Glad you could confirm that it's not the connectors or the logic board though.
- de Lena Fox
Thanks for the reply!
Battery was replaced by me. Which I have done many times .
The device is not recognized on other PC's either.
Perhaps a chip/component on the logic board needs to be repaired? I just don't know which one would relate to this issue.
- de Isaac K
